dphillips067
I have a 2001 expy eddie bauer with 5.4 and i want to disconnect the a4wd how do I go about doing this? any help would be great.
Easiest way is to pull fuse 104 in the fuse block under the hood. 30amp close to firewall. This will disable all 4wd functions.
You will see no saving in fuel economy if that is your intention because the front drivetrain components will still spin it just will be unable to engage the clutch in the transfer case to apply power to the front wheels.
There is the brown wire mod if you want to be able to turn it on and off on demand. Do a search on this site.
is that on the "newer" 1st gens? cause i know on the 97 98s the front is disconnected when in 2wd. because it has a vacuum line attached for the front diff to engage it. allowing it to freely spin. like disengaging hubs on "4x4" trucks. cause i can go under my truck and spin the front d-shaft of my truck and my dads jeep, when his hubs are unlocked. but i cant on my uncles jeep cause his are spinning full time.
well lucky for you guys. i HATE it. just another thing to break/not work. haha
