Door keypad code
creef14
VA
Is there a way to get this code without trying to stuff myself under the front dash?
Bedrck47
Elizebethtown, PA
If you can't look and see it or you don't want to stuff yourself Then get a mirror and a flashlight and look above the fuse box and you should be able to see the numbers ********* Numbers on the Security Module Or you can use your cell phone and take a picture
I had a mechanic at dealer that was thinner, and knew where to look, read it off to me.
KG974316
US
You can reset the code easily. What year is ur expo
Sent from my SM-J320P using Tapatalk
whitelightning99
Pa
try using a good light of some sort and use your phone do a video with it but honestly its not all that hard to see it
KG974316
US
Man all u need is the code from under the dash then all you have to do is go on youtube and search ur year and it will tell you what to do. That easy. I reset mine in ten mins.
Bedrck47
Elizebethtown, PA
Totally agree but it appears that the OP doesn't want to stuff himself under the dash to get the code
and being he asked How to get the code I don't think he is interested in resetting the code at this point
C
creef14
VA
I can see the box but i cant manage to see the code or get a picture. For some reason the box seems to be tucked higher up on mine than in other pictures I've seen.
sharprd65
