Easiest way to siphon gas from a 1998 ford expedition?
Edwardi
I actually own this car and you can check back in my posts.
Anyway, the car may go to the junk yard and I have a full tank of gas. I was having difficulty with putting a tube down the gas tank, seems that maybe there is a screen or something that blocks it?
Does anyone know the easiest way to siphon gas on this car? Does the car possibly have a fuel rail shrader valve test port?
Thanks for any tips you can give me here.
Expd830
Chicago
Are you using a siphon from car parts store? I have a 2000 and did it many years ago, but it took a awhile for it took get up and running
Expd830
Chicago
If it doesn’t work you can do what the gas hogs are doing and just drill a whole in the tank and drain the gas
JamaicaJoe
Oviedo FL
Don't drill it...
The gas tank actually might be valuable. I have a 2001 and was looking for new or used plastic tanks and found them very expensive at wrecking yards.
I thought I had some bad gas and tried to get a siphon hose into the filler. It was impossible. Use the fuel pump to draw the fuel from the tank and past the filter to a proper container. Be careful of spillage and sparks.
