bcmaxx
Does anyone do custom tunes for edge cs anymore? Or custom canned tunes or anyway I can upgrade software? Pissed php won't do it
Yes, Ive played with all I can , but I'd like the a/f ratio a little richer, It's running a bit lean with the k&n intake
I think people make way too much fuss about 'custom' tunes. In reality, unless your setup is radically different from the normal mods, you really don't need to spend the time and money on a custom tune.
Let's face it, most of us have basically the same setup. A cold air intake, perhaps headers, and a high flow exhaust. These are the same perimeters that companies like edge use when making up their tunes.
The times when a custom tune is needed. Engine swap in to a different vehicle, adding forced induction, etc.
Are you monitoring you air fuel ratio via a wideband?
The pcm should run stioch regardless of your mods while in closed loop. Curious what your indicated air/fuel ratio is while at W.O.T.?
I dont have a wideband installed, justgoing off plug readings. put about 3000km on a set of plugs after cai, pulled em and they are white. the old wones were light tan.
