Engine running to lean
F1vel66a
Salem, Or
98 expy 5.4L running lean. A little back ground I pulled my dash apart replaced heatercore and shift cable. Now my obd2 is giving me a p0171 and p0174 is this just bad o2 sensors or is there by chance I forgot to plug something in? Thanks
toms89
technical advisor
MD
If it happened after you pulled dash apart and did some repairs check to make sure you plugged any and all vacuum lines back in. Any hiss coming from the dash area??
flyin
WI
I would check the pcv vacuum tube assembly for soft or folded rubber connectors. You may have disturbed one while disconnecting the heater hoses. It runs from the rear of the intake to the pcv valve. I snapped mine while flushing my heater core recently.
F
F1vel66a
Salem, Or
No hissing that I can hear inside the vehicle. I will look at my pcv when i get home in about a hour
F
F1vel66a
Salem, Or
Another thing I noticed today was a ticking nose behind my dash when I step on the brakes I believe its a electrical tick
F
F1vel66a
Salem, Or
Update looked under hood and found a cracked hose near the pcv.. Thats what I get for working in the dark lol
Jefes_Shyt
