mic_1011
wingrg did you check the line all the way in the back behind the throttle body. its kinda hard to see and to get to. i'm 6 ft and had to lay across the engine bay to get to it was completely off in my case and kept my expy from staying on. the next thing is to get a code reader even though its not throwing a code you might be able to pull one. this will help if its a bad coil. instead of changing all off them. the code will pinpoint which coil it is then you can just replace that one, also happened to me
