Bowesmobile
1997 expy. with 4.6L 4x4 rear air and heat. 200k. Heater core replaced at around 100-110k. Thermostat, water pump and fan/fan clutch its unknown if its ever been replaced. Antifreeze level is good. Now to the problem.
I get decent heat when I'm driving on the expressway or any time the truck is moving. But when I come to a stop at a light the heat slowly disappears. Then when I start moving again the heat comes back.
So in my mind this either means the impellers on the water pump are bad. Or the fan clutch is not disengauging and its over cooling the motor.
Last night I popped the hood when I got home and the engine compartment wasn't warm like I would think it should be following a 50 minute drive with most of the time spent on the expressway. The upper radiator hose was warm to the touch. But not hot. The heater core lines were the same.
The truck warms up steadily when I start driving. Which leads me to believe the thermostat is working properly. I'd like to have great heat without throwing parts at it. Any help is appreciated!
