Declansdaddy
So I have the p0401 code which was EGR flow insufficient. I took the throttle body apart and sure enough the ports were stopped slam up. I held the EGR port vertical and filled the pipe with carb cleaner and not a drop came out the other end (2 smaller holes). Got that all cleaned out good and reassembled and went for a test drive. Under acceleration my CEL flashed and then stayed off. Got home and checked for codes and the 0401 code was gone however I'm getting a p0300 random misfire code. I'm assuming this means it's random cylinders rather than a specific cylinder. Any ideas on what could be going on? FYI it's a 99 4.6 and I put plugs and wires on it less than 500 miles ago.
