There isn't a relay to be changed. You need to use Forscan or take it to a dealer to have bulb out warnings turned offGot a novita ep27 flasher relay to fix hyperdlashing from LED turn signals. Where is OEM located on a 2016
They have The same listed for my 07 and it's doesn't exist at least on mineAn online Ford dealer lists a standard Ford flasher/relay for the 2016 Expedition.
https://parts.lakelandford.com/p/Fo...TURN-SIGNAL-FLASHER/54303716/2L1Z13350AA.html
I don't know if the site is correct or not but if Ford hasn't relocated it from earlier models it will be between the main light switch and steering column behind the lower dash panel. It should have a black plastic cover over the relays that will need to be removed. Pull the relay up to remove while holding the bracket if possible. The bracket breaks easy so be careful.
Once you find it you will wonder what dumb azz put it in that location.
Yup, returned mine the other day after I was told at dealership the relay is now part of a computer module and the novitas are uselessJoin the Happy Novita Customers, we have tshirts....and apparently useless relays...
