fog lamps
jabert
Acworth, GA
The fog lamps on my 2001 Expy EB don't work . . . haven't since I bought it, used, about a year ago. I know the obvious - bulbs are burned out, fuse is blown, trying to use them with the high-beams on. I replaced the bulbs and fuse; I only try to use them when on low-beam headlights. Any ideas what the problem might be?
jim midd
Baltimore
if bulbs and fuses are good I'd look at the switch . Pop it out of dash and see if you get voltage out when switch is activted for fog lamps
Half relay 206 in the main fusebox under hood is for the fog lights. You might switch one of the other 3 with that one to see if lights pop back on. Let us know your findings.
z168
Cali
Unless youre hell bent on having them work factory, you can wire them up independently. Mine fire up separate from the low beams BUT only with the parklights on
