They make an injector needle for your grease gun that plugs onto end to do just that.Yes I have an 05 4x5 that did something similar but not that loud, it was definitely the lower ball joints..I actually punctured a small hole in the boot with a heated nail on the end of some vice grips & shot in some lithium grease with the straw attachment from the side of the can..it totally worked! & have not heard it since...I did this with plans on replacing which also includes new boots but it was really getting on my nerves..oh & there was a dust build up around the bottoms of the boots which I think is leakage..hope that is all that is wrong with your '04.
Sent from my SM-N950U using Tapatalk
Sounds like it. It's using more of a clicking than a clunk but yes the hubs will only do it in 2 wheel drive because that's when they have vacuum to hold them disengaged. When you put it in for auto the vacuum turns off and they will lock into place so no more clicking.It does it in 2 wheel drive only I’ll replace the sway bar end links and lower ball joints. could the iwe be making that noise ? If I spin the wheel i hear a clunk
