valenrandy
Ok, So this morning I actually had time to replace my front wheel hubs. When I first got the truck I had noticed what I called a hum between 5-45mph that I could somewhat ever so slightly feel through the steering wheel.
I purchased through rockauto a pair of Timken hubs and from the dealer some motorcraft gx-11 hub grease.
Considering I am not what you would call mechanically inclined, this was a fairly straight forward job.
The only issue I had was as soon I took the wheel bolts off. The darn tire just would not come off. Believe me I was stumped for a bit. I wondered if there was an additional bolt under the wheels center cap lol!
Well about 10 minutes of head scratching later and a quick search here I saw another person had a similar issue and found my solution.
The wheel and hub face had pretty much rusted together and while I did not loosen the bolts and dropped the truck, I just took a mallet to the tire and they eventully let go.
I cleaned the surfaces and applied anti-sieze to the mating surfaces for future ease.
Anyway it was fairly straight forward and took me about 1 hour each side.
Put everthing back together and took the girl for a spin. She drives smooth but the sound is still there :-(
Do you all have any suggestions as to what other component/part that could cause a hum that increases in frequencey/speed that can sound like a badish wheel bearing??
Second Item:
I see that i have the brown boots under the cops and I want to go ahead and get the all plugs and cops switched out.
Since i have the brown boots that means I have to use the motorcraft sp509 plugs ($7.38)correct?
The site states the sp515 plugs are for black boot so I believe I cannot use those.
Regarding the boots, I was looking at rockauto for the brown boots and I see the DELPHI Part # GN10233 for around 38$ each and the MOTORCRAFT Part # DG508 for 45$ each (but I cant tell if its a brown boot or not).
Anyways, are these the best prices for the plugs/cops and is this a good setup? Looks like this will cost north of 400$ to do myself and I'm just trying to have a reliable truck for a while and I'm willing to put $$ for the right parts. I take this as an investment to help mitigate future problems one peice at a time.
As always, thanks again for your help as it is always appreciated.
Second Item:
