gears351
Ok, 116k miles, new brakes (6k miles ago) and now the ABS light comes on, the pedal growls & vibrates and it doesn't want to stop like it used to.
It sounds like the pads are gone so I pulled the wheels and the rotors are clean and smooth and the pad friction material looks brand new (inboard & out, front and rear). When braking the growl comes from the firewall by the pedal, the pedal jounces around and the truck takes a bit longer to stop - sometimes the ABS light is on sometimes it's not.
Searching the forum I think I'll try building a shield around the tone ring pickup on the steering column (there's a TSB about this) but I was wondering if the truck's diagnostics would tell me the ABS code or if I need a dealer to scan it for that.
Is there something common that goes out on these trucks that would cause ABS problems?
Thanks
Thanks
