Time for a flush ?
Sounds like the blending door, but I would go ahead and replace the thermostat first.....just in case.
Hi
It could well be one of those problems, but have you considered doing a reverse flush on your coolant system ? Its a job as disliked as changing out the Expys spark plugs but equally worth the effort.
I've experienced similar problems and after changing out a perfectly good 'stat to no avail, I flushed out the system. On my mechanics' advice I paid particular attention to isolating the front and rear heater cores to give them a good blowout individually (clamp off relevant hoses to localize flush circulation). I flushed out a large amount of what I can only describe as small blobs of very soft clay from the system. Looked just like sh#t in my coolant !
That and rust flakes that never seemed to end (I was filling buckets from the exit point to see when it truly ran clean/clear).
After a couple of hours of creative plumbing I re-filled and ran. Then test and top-ups etc. Boy that heat was crankin' and consistently so. No more complaints from the wife about little heat !
Hope this helps !
Now onto the rest of that darned honeydo list.
