Just to try to counteract some of the misinformation here: Ford has TSB’s concerning induction services specifically because of “some” cases of turbo seal failures due to turbos getting hot during induction services. Two things to note here...
1. There have been a ton of successful induction services that never reported any issues even years later, so there’s no data that suggests this is a for sure occurrence with every induction service.
2. I specifically chose the CRC because they designed it for the ecoboost engines. The specifically tell you do NOT exceed 3500 rpm during the service and keep it at 2000 rpm. This could likely be the difference between cooking or not cooking the turbos. Yes I’ve read the TSB and yes I’ve read the few horror stories of ecoboost induction treatment failures and yes I’ve watched practically all of Maculoko’s videos....and I did it anyway in a controlled manner without raising rpms high and following their instructions to a “T”. If I cooked my turbo seals, I’ll be happy to report back on here so I can be sure to save the ecoboost masses from following suit. I don’t perceive this will happen. Now that I’ve said this, I spent some time looking through your other posts on this site RJDELP7 and realized that you’re not rude only to me, it seems you’re an equal opportunity jerk to others on here, so I will refrain from engaging with you and let you flame out all by yourself. After all, that’s what the ignore feature is for...first time I’ve actually had to employ it.
Note, JSKI, none of my response is directed at you. You’ve been fun to banter with on other threads and actually offer respect and good info.
So back to the original point of my thread... my next experiments will be to perform a new hypermile test with my side mirrors folded in, my roof rack removed, and my running boards deployed because maybe they will provide lift, thus making the truck lighter, and thus saving gas. And after that, I’m going to install an HHO system on the engine which should net me another 12 mpg.
Actually if you want to read something fun, I’ll be borrowing my best friends Prius today and tomorrow for some long distance stretches. I’ll be seeing what numbers I can squeeze out of it and report back here just to keep things interesting [emoji6]
