It is pretty damn close. Every manufacturer will have slight differences but from what I have owned (6000K and 8000K) those are nearly an identical match.
legal restrictions?
legal restrictions?
They are illegal in Florida and annoying too.
The trick with HID bulbs is whether they have gotten their "DOT APPROVAL" or not. If you look on the box, they will specifically say "DOT APPROVED". If the bulbs have that, then you can run them in all 50 states. If they don't have that, then they are restricted to off-road use only. Now, keep in mind, to the best of my knowledge, the only HIDs that are DOT APPROVED are 35W HIDs that are in the 3000K, 4300K, 5000K, and 6000K color range. Any others, you would need to do some research into. Even the 3000K ones are questionable. So, look at the box and go from there. Also keep in mind that the bulbs will also have the "DOT APPROVED" lettering stamped on them. That way if the cops give you any trouble, you can simply pull out the bulb and show them the stamping. To the best of my knowledge, all 50 states have a statement in their laws that all lights used on the road must be "DOT APPROVED". By having the DOT approval, the light has the proper light output as defined by the government.
