Jingling sound coming from the front right tire assembly area
KOTU
Los Angeles, CA
My truck is a 2007 Lincoln Navigator L, Triton 5.4L 3V. When I drive over a shallow pothole in the road, I hear a jingling sound that comes from the area of the right-side front tire. The sound lasts only a few seconds and sounds like a stack of thin fender washers being dropped like a stack of poker chips. I recall having the same issue with a 2005 Expedition before I sold it. When I go under the truck to investigate the sound, all of the components a tight and solid.
Has anyone here had this issue?
Trainmaster
Old School Member
Rockaway Beach, NY
Could it be the tire pressure monitor transmitter loose and banging around in your tire? Or a loose brake pad or bad ball joint?
Jack up the tire and spin the wheel.
99WhiteC5Coupe
Sounds like a loose or defective sway bar bushing / link assembly (not a bad sway bar).
wk99
I know this sounds crazy but could be a loose wheel center cap, in addition to what everyone else said? Best of luck
Modelcarguy
Algoma
Check the run out in the hub too. There is a set of washers and a lock ring that can go bad. However, my guess would be a bad sway bar bushing or a bad ball joint. (Top one most likely.
purevw
I've had caliper keepers create a jingle if they've broken.
