Key Question
xfiles67
Va
Do the keys for the ignition have a chip? Looking to get an extra key but unsure if I can just get one made...
Thanks
Bedrck47
Elizebethtown, PA
Check your owners manual for the procedure to program a new key You may need one or two original keys. You will need a blank cut key that has the chip.
Gruz7
North Smithfield, RI
Thanks
They do have a chip, therefore require programming either by a reputable programmer machine or with OBP... I am a part time locksmith and do car keys with chips all the time.
Lostneye
NY
If youhave 2 keys now you can program more without special equipement. Only one key now you have to see a locksmith/dealer.
I have bought factory Lincoln keys for my Navi and another Lincoln on ebay for cheaper than generic chipped keys locally. You email them a quality pic and they will cut them as well.
X
xfiles67
Va
I have 1 physical key and 1 key fob.
I've seen the video on programming a new fob, that's pretty simple. Just going for another actual key for now.
Bedrck47
Elizebethtown, PA
Again check in your owners manual If you don't have one you can download a copy at
owner.ford.com
igozumn
near Kansas City
Mostly true. There have been some places (hardware stores, etc.) that are advertising the ability to "clone" a key. What it does is mimic the programming in the single key that a person may have. They end up with 2 keys that will start the vehicle, but the vehicle still thinks there is only one key programmed. Not sure what happens if you take the 2 keys (with one being the cloned key) to the dealer.
Also, there is a limit to how many keys can be programmed to a vehicle. The first couple of years for Ford (96,97-ish....) it was 8 if I recall. Now, I believe it is 16???, but the owner's manual should have that info also. If a vehicle was used in a fleet, church, etc, there may be a bunch of keys out there and when you go to program a new one, you may be over the limit.
46L281GT
KY
order a elm327 wifi adapter from amazon for 15-20 bucks and order a couple of keys. then download the free forscan app and program them yourself. much cheaper than anything else.
Skauber
Cagayan de Oro, Philippines
If you go the route of programming it yourself with FORScan, which is a very viable option if you have some basic computer skills, then be sure to follow the instructions in the FORScan forum PRECISELY, which includes testing the new key first to make sure it is compatible. Some chinese key blanks may not work. If you do not test it first, and then proceed to delete current keys and reprogram new ones, if you do not have minimum 2 working keys you will not be able to complete the programming and thus will not be able to start the vehicle.
