hey guys - i have a 08 navigator which is pretty close to the expedition. I'm having a turn signal issue, my left turn signal doesn't function at all and when turn signal is in neutral position my right turn signal goes on and when i signal right it also works properly but i put it to signal left to keep the right from going on. For a small period of time when the left worked, didn't work, worked, didn't work...anytime the left worked before going bad the neutral turn signal issue would go away.
I've checked the bulb and it is fine, hazards and everything else works as it should. There wasn't much corrosion in the socket but cleaned a little out. On our and the expedition models there is no multifunction switch in the steering column. Outside of replacing the turn signal assembly, examining the harness and socket any thoughts on what to look at?
Very much hoping it's not the junction box needing to be reprogrammed just for a left turn signal
