Loss of Power/Stall
Cheddarhead
Pewaukee
'98 Eddie Bow Wow edition with the 5.4 engine...
We've had it for a decade...and it's got 240,000 miles on the OD...just think of all the gas this bad boy kid-hauler has consumed over the years...
My daughter was using the truck, visiting friends a couple of hours from home...calls in a panic, saying the truck has "died..."
Engine runs, but very rough, and no power through/to the axle. I'm 600 miles away.
My wife says "Oh yeah...they said it needed a "speed sensor".
Months ago (grrrrr!)
I'm an "OK" shade tree mechanic...but couldn't find any references to this sensor...
Any ideas/suggestions as to what the problem(s) might be, and whether I can tackle this in the driveway?
Thanks!
Cheddar
2002EB
Florida
This probably won't help but I think the speed sensor will effect the ABS and speedo only. Should still drive.
I did have an episode with my 02 4.6 this week. Had some weird electrical problems. My truck was wrecked in the front a few months ago. Long story short, loose ground behind left headlight on rad support. Flash to pass and rear wiper caused it to stall and not restart. (among other issues)
C
Cheddarhead
Pewaukee
Originally posted by AvroAero
What was rough? The output or the engine running? If you are 4wd with A4wd then you have 2 speed sensors.
The vehicle has the auto 4WD (4WD Hi/Lo/Auto) option.
My daughter indicated that the engine ran, but that there was no response when she pressed the accelerator....
I realize that there isn't alot of info here...but I haven't observed this symptom myself yet. My wife indicated that this has happened before, and that shutting the truck off and starting it a few minutes later was effective in restoring normal functions.
sharprd65
