Well all this time I thought that it had a windshield leak on the driver side. Many others have had the same issue with water going down behind the dash and onto the GEM box. This has caused me so much fustration and hair loss tring to find the prob. Anyways, Monday afternoon my sunroof decides to break so I decided to pull it and fix it myself. Upon removal of the sunroof I started to pull the drain lines off one by one. Boohya.. I couldnt believe it. Ford ran the front drain lines on both sides over a power line going to the vanity mirror and the overhead console. That drain line becomes pinched once the headliner is put back up. Heres the catcher.... the power line is bigger on the diver side which really pinches it. Mine was smashed completely shut on the driver side and the way its designed I could see this being a a prob for anyone with a sunroof. There is really no way around it. To remedy the problem I found a harder plastic line to act as a sleeve for the exsisting line. I really hope this is the prob on mine!
How many of you that have leaks on the driver side have sunroofs?
