O/H temp LED 2000 XLT
lonestarjeff
The Colony, TX
My overhead temp/compass LED readout went off a couple of weeks ago. Has anyone repaired, replaced theirs?
Jeff
Ulver
Tennessee
If you have a soldering iron and solder, you can probably repair it in an hour. This issue usually occurs due to a fallen off resistor or some other component from the circuit board. Here's a post I made in another thread on what it could be and how to fix it. If you need a visual, there are a couple of videos on Youtube on how to do it.
https://www.expeditionforum.com/posts/354093/
uscgmac
US
I bought a used one off of eBay from a junk yard for like 35 or 40 bucks. I would try the soldering first then if that doesn't work try eBay.
Sent from my SM-T350 using Tapatalk
lonestarjeff
lonestarjeff
The Colony, TX
My plumbing solder skills are better than my electrical solder, but I can get by. I'll report my results.
Ulver
Tennessee
It's pretty easy, yet if you have big fingers then tweezers may come in handy when dealing with the fallen off resistor/chip.
lonestarjeff
lonestarjeff
The Colony, TX
Tweezers indeed, no way I could have done it without them. Can't believe I originally posted this thread so long ago, but I just got around to fixing the dark display. Here's a couple of pics....
Both of the 510 resistors were lose on one end. It wasn't pretty, but I got them both re-soldered(not on the 1st or 2nd try) :)
Thanks everybody for the links & comments.
Ulver
Tennessee
Yep, loose resistors, there you go! Glad you've got it figured out.
Apollo02exp
Diego
Rapid Electronics
Automotive Electronic Component Repair
Programming / Odometer Correction
Austin, TX
We are a proud ASE/L1 certified repair facility
This is a repair service to your Overhead Console Temp Compass Fuel Display.
You will need to send us your unit after purchase.
THIS REPAIR SERVICE IS FOR THE FOLLOWING MAKES AND MODELS:
1998 – 2008 Ford F-150
1998 – 2008 Ford F-250
1998 – 2008 Ford F-350
1999 – 2005 Ford Excursion
1998 – 2005 Ford Expedition
1998 – 2003 Ford Explorer
1998 – 2011 Crown Victoria
1998 – 2011 Grand Marquis
1998 – 2005 Lincoln Navigator
2003 – 2004 Maruder
1998 – 2002 Mountaineer
1998 – 2004 Lincoln Town Car
IF THE ITEM SHOWS NOT COMPATIBLE WITH YOUR VEHICLE THAT IS OK. JUST MAKE SURE IT IS WITHIN THE YEAR AND MODEL LISTED ABOVE. EBAY ONLY LETS YOU ADD A FEW YEAR MODELS IN THE AD.
THE UNIT IS REPAIRED THE SAME DAY WE RECEIVE IT AND IS SHIPPED BACK USPS PRIORITY MAIL.
Common Issues:
Dim/Dead Display
Dim/Dead Back Lighting
Intermittent Display Lighting
This repair service will fix all listed issues.
REMOVAL INSTRUCTIONS:
Remove the 1 screw at the front of console (near rear-view mirror). Grab the console firmly and pull down.
Disconnect electrical connector, then remove the black display from the console with a T10 Torx Bit. We only need the black display unit. No need to send the entire plastic console.
Box it up and send it to us for repair. You pay to ship it to us. We pay to ship it back to you.
Free return shipping.
Same day repair service. Lifetime Warranty on the work performed.
These are common failures of the unit, and can be repaired and upgraded without replacing the unit, providing a permanent solution to the problem with a LIFETIME warranty on the work performed.
djahmed786
