OBD2 not communicating
Joanne
texas
my OBD2 is not communicating with the computer but I have 12.6 volts. anyone know the next step i can try? it runs like a champ.
Yupster Dog
Super Moderator
Super Moderator
check the fuses.
Welcome to the forum
J
Joanne
texas
ive looked in the manual and online there are no fuses for the OBD@ this is a 2017 year model.
GlennSullivan
Yorktown NY & Jupiter FL
Do you have ignition or acc mode on when testing?
Are you sure the device is fully connected (bottomed out) and straight into the vehicle port?
Have you tested the device you are trying to use with another ford ODBII vehicle to ensure it is fully functional?
Have you tried another ODBII device, known to work on other Ford vehicles on this vehicle?
Are there any pins bent, missing or damaged either on the cable connector or ODBII connector port?
J
Joanne
texas
It did not pass at the car inspection place twice. I also tried a device and it didn’t work. The ford dealer is saying $515.00 for a new dash harness
Yupster Dog
Super Moderator
Super Moderator
Check all fuses to see if any are blown. Everything in your vehicle runs off a fuse somewhere.
Do you have anything else that does not work?
J
Joanne
texas
As far as I know everything works. Ok I will try all the fuses. Thank you so much!!!
J
Joanne
texas
Well I took it to the dealership they said it was a fleet vehicle before I owned it and they put a tracker on it and that’s why. So they bypassed it and did my inspection and it passed. Crazy!!
