One wiper and screen wash not not working windscreen.
Hamfisted
Ft Lauderdale
The two front wipers are connected by a linkage under the windshield cowling. So if the driver's side is working I'd say you have a disconnect or broken linkage. The washer spray nozzles are also in the windshield cowling and are connected by a common feed tube from the pump outlet. Sounds like you need to pull the cowling up and take a look.
Gary Waugh
Princeton, TX
The mechanical linkage probably broke and when it dropped down it pulled the rubber pipe feeding the windscreen washer jet off.. as stated, remove the cover and take a look, should be pretty easy to see both problems.
FukNshT
