puddle lights
CITYBOY63
laurel, md
2nd gen expo puddle lights no working. anyone has ones that work do they light up when you unlock with the remote. I'm missing this feature...
Gruz7
North Smithfield, RI
Could just need a new bulb if they never come on?
Hamfisted
Ft Lauderdale
How did you break a T-10 driver just taking out a screw ?
To remove the lens you remove the T-10 screw (push the mirror body all the way forward to access the screw...) and release the retaining spring from behind the mirror glass. The lens will just drop down free. Use a clear 921 bulb for the courtesy light and turn signal light.
-Mike
Compress this tension spring with a long flat screwdriver and push it down to release through the hole....
C
CITYBOY63
laurel, md
thanks for the help gang finally figured it out got the bulbs changed and everything is working properly . will post pics soon.
djahmed786
