E36Graduate
Does anyone know the difference between gen2 and gen3 regarding the cooling system???
I need to crawl under and take a look based on a noise I hear that wasn't present on the gen2 that I am experiencing on our 2012....
Symptoms: Car in park, at idle and normal operating temp (a/c not on). A intermittent cycle occurs very similar to a a/c compressor engaging where the motor revs change a little and I hear a vibration. The vibration and revs go back to normal a few seconds later....this happens continuously and the a/c is not engaging either.
Truck not overheating and draining very well.......it's just something I'm trying to figure out.
I did notice the idler belt pulley in the center of the motor has some play that I'm not sure is normal.....no squreeching noise though? Can visually see play in that pulley when running and the revs change and vibrations start.
My gut tells me this is some type of electric fan cooling system that wasn't present on gen2? Could the vibrations be part of the electric fans kicking on and causing the idles to slightly change for current draw?
I guess I need to get under and take another look!
