I replaced my driver side head on my 5.4l Triton in my 98 expy I had no knock prior replaced due to broken spark plug hole. Now I have a random knock thzt sounds as if is coming from the intake. It seems to happen more or less after the engine is hot and driving for a few hours. Cohld this be from a under tourqued head (50 ft lbs) over tourgued cam guids? I used all the parts except valves from my old head. I wax thinking timing chain at first but it seems to be that would be Almost all the time not after extended trips. Also if I let it sit for a hour or so the knock goes away. I have 10x30 oil in it but it started with 5x20. It speeds up with RPMs and slows down almost as if it was timed to the engine. Cel codes are p0171 & p0174 banks to lean (got a cracked vacuum line fixing it today) anyways any help would be appreciated
