new ford owner
2003 eddie bauer 4x4 5.4 litre...rear brakes are not working...replaced front calipers, caliper brackets, pads and rotors. I have replaced rear pads only...rear calipers and rotors are good. rear caliper pins and pistons move freely. there was minimal wear on rear pads when changed..no brake dust on rear wheels...that was a couple months ago....noticed front brakes and components wearing over the last couple of months significantly...excessive brake dust and overheating of front components...rear pads show no signs of wear since changed. I opened bleeder valve on rear caliper under pressure and only a trickle of fluid comes out... no obvious leaking at master cylinder, no loss of fluid from resevoir, no cracks/leaks in brake lines noticeable. pedal does not feel spongy just has a longer travel than other trucks/vehicles i drive or have driven...PLEASE HELP...master cylinder proportioning valve?...I did notice a black box that all brake lines go into and out of before heading to calipers...this is a black square plastic box that sits next to the radiatior on the drivers side below the air breather, about six x six inches. not sure what is wrong any advice appreciated... by the way no dash indicator lights showing..
