Rear Gear Ratio?
Discussion in '1st Gen - 1997 - 2002' started by Jay87LX, Aug 31, 2012.
  1. Jay87LX
    Jay87LX Full Access Members
    527
    24
    Oct 2, 2011
    Cleveland oh
    Is there a way to tell via the VIN what is my rear gear ratio?
  2. Fila571
    Fila571 Active Member
    25
    Aug 15, 2012
    Kansas City Missouri
    Gear ratio
    Door tag on drivers door has gear code under axle, H is 3.55 most common, or H9 is 3.55 limited slip fila571
  3. Thermo
    Thermo technical advisor
    46
    1,407
    57
    Apr 18, 2011
    Jay, like was mentioned, look on the door tag under "AXLE". You should see either an "H" followed by a number or an "L" followed by a number. From there, you can get on the internet and search on "ford axle code XX" where XX is the code you found in the door jam. You will find out more info than you ever wanted to know.
    With that being said, as long as you have not messed with the setting of your speedo (ie, getting your ECM flashed), in short, if you are turning 2150 RPM at 72 MPH, you have 3.73 gears, if you are turning just under 2000 RPM, you have a 3.55, and if you are down around 1900 RPM, you have the 3.31 rear end. 3.31 rear ends are very rare and really only came in the 97/98 trucks with the 4.6L motor.
Share This Page
