Rear hatch button-2019 Max
tpf903
ny
The rear hatch button stopped working. The dash button works, the key fob button works, and the kick sensor works.
Any ideas?
Jace
Utah
Any ideas?
Quickest fix till you can get it into the dealer is press the lift-gate button and then press the ridge to the right of the button. Works every time for me.
T
tpf903
ny
That works! Why does it work? What's behind the ridge? So bizzare.
aggiegrad05
North Texas
It's not what's behind the ridge, it's just that button gets hung up somehow and pressing the ridge releases it. Holding the button is how you set the liftgate max open height; when the button gets hung up, the vehicle thinks you're just trying to set the height not close the gate.
Mine was a quick dealer fix when I was in for an oil change, just swapped the whole button assembly.
Artie
Georgia
As mentioned, probably the button. Mine did same thing and also was causing current draw. Warranty fix.
Going_Going_Gone
Phoenix
In the "plus" category, you are just about the only owner on here who has stated that their kick sensor works.
expresspedition
