Rear Vent Windows
cml185
ohio
I have only had this beast for 4 months, and this forum may make me keep it for 10 more years. I have an 03 EB 4WD. The rear vent windows do nothing. Any idea where to start?
Stoned06
Milwaukee
Fuse or bad motors would be a good start. If the fuse is good, put a multimeter on the motor connectors and see if they get power when switched on. If so, bad motors. If not, a short in the wiring or switch.
amahay
Kansas
sometmes they just stick to the rubber trim. have someone push the button while you push out or gently twist the arm the moves the glass out.
sgtowing
Supporting Members
Valrico, Fl
Especially if they haven't been opened for a long time.
C
cml185
ohio
Rear Vent Window help
Thanks for all of the ideas! I will check it on Sat, as long as it is over 30 degrees!
Ford Frank
Oregon
I just bought an 2003 EB. Its a stupid question, but how do these windows open? Are they power or manual?
Bedrck47
Elizebethtown, PA
They are motorized
If yours aren't working check fuse #22 with a meter
Also check your owners manual for the location of the switch
Ford Frank
Oregon
I checked the manual again. Looks like the switch is next to the moon roof switch. Thanks!!!
M Bennett
