Removal of Headlight Sun Damage
Sgt Darkness
East Tennessee
Anyone found a home remedy for headlight Sun damage? My Expy is fine but my other vehicles go from lite damage to heavy. I know you can get a kit to repair Sun damage but is there anything homegrown out there that works as well as a kit?
crector080862
US
I already did my BMWs give me the process you start with a heavier grade sandpaper and work down I believe to 4000 grit then you use two different types of rubbing compound with finer and finer grits and you clean them very well and you spray them with ultraviolet protection polyurethane turned out really nice and no problem after that I'm fixing to have to do the same thing to My Expedition
Sent from my SM-G892A using Tapatalk
JerEazy
Sarasota, FL
This except I would go finer than 400 before compound. Griot’s Garage as a set of “machine polishes” working themselves all the way down to glass polish that should do the trick.
crector080862
US
Or if you'll read I hope I said I went all the way to 4000 threat before polishing it seemed really weird sanding my plastic lenses can you wipe them off and they look totally hazy like you're fixing to paint a car but the end product was amazing. I think if I did it again I would take the headlights off of the car has I had to tape them up about 10 times because the water would just make the tape come off of the body of the car. I really didn't want to scar my BMW paint job up
Adieu
SoCal
Redneck method: wipe on WD-40
Repeat as needed
gixer2000
Retrofit or Bust
Massachusetts
Sand away the yellowed coating with 400 grit then work up to 1000 grit. Prep and Spray with a 2k clear coat. never touch them again!
JerEazy
Sarasota, FL
My mistake - bad eyes - had nothing to do with day off work cocktails.
jeff kushner
North of Annapolis
I've had excellent results removing yellow from headlights and even a Vintage motorcycle windshield.....with "Plastic restorer" and a polishing wheel on a drill motor.
It is a Polishing compound so the particles break down smaller and smaller as you work it, eliminating the need for different grits etc.
Rubbing compound particles on the other hand, do not get smaller as you work it, therefore are misplaced in this application.
This windshield was so yellow, you could not see through it.....an hour later.....
jeff
ExplorerTom
Colorado
In my experience, these methods work OK at first, but quickly re-yellow.
Replacing the whole light assembly is the way to go. And sometimes about the same cost as buying all the different products and kits.
lvcjt702
Lost Wages
Try some DEET.
If you've got some skeeter spray laying around spray it on and let sit for a few minutes. Wipe off with a rag not paper towels (ask me how I know). Repeat until clarity has been restored. Clean with denaturized alcohol. Spray with clearcoat and be amazed!
Sent from my SM-G935P using Tapatalk
