I was hoping I could do it without lifting the engine as I don't have immediate access to a lift. I'd have to take the vehicle to my dads shop to do that. If the pan has to be removed i'll likely just put the new filter on and put oil back in it and do that at a later time.
I flushed it, that's why I wanted to take the pan off and clean it and the screen. But when I changed the oil the oil didn't look bad at all. No sludge, chunks, metal etc came out of the drain plug. Filter didn't look bad either. There is a slight leak on the pan, so i'd end up changing the gasket eventually. I might just wait until I get everything else fixed.
It'd be nice if I could flush the screen/pan from the drain plug - maybe pressurized solvent or something. But that'd probably be worse then leaving it as is!
