Running Boards for 2019 Expedition Max
MissAnn83
Granger, IN
I have a 2019 Expedition Max limited and would like to get running boards for it since I am pretty short. I cannot find another since my vehicle is a max. I do not want power operated, since I have read so many issues in regards to those. Anyone have luck finding stationary running boards for the max?
99WhiteC5Coupe
My 2015 Expedition Limited (not Max) came standard with stationary running boards. The power board were optional and I did not get them when I ordered the vehicle.
What type of running boards did your vehicle come with?
Going_Going_Gone
Phoenix
MY experience with non-retracting Ford side steps is that they are not positioned for ease of entrance/exit, but more likely positioned to keep your feet from slipping through the bar/step and breaking an ankle (potential product liability issue). They are positioned such that you take a big step up to the fixed bar/step and then a tiny step up onto the floor. The Ford or AMP Research power steps position the step in more of a middle position making entry or exit less awkward. Had my Expedition not come with standard Ford power steps, I would have purchased the AMP Research ones. I had those on my F-150 and in the ten years I owned it, the only issue were: the LED puddle light on one side coming loose and getting crushed by the retracted step, and a failure of the control module to operate the step on one side. The nice thing about the AMP products is that they help you troubleshoot and then sell you only the parts that you need, unlike Ford dealers who are required to sell you an entire step assembly with motor and idler arm no matter which of them failed.
wakeboarder
Fort Lauderdale, FL
Your vehicle should have come standard with power running boards. Could they still be there and just not turned on? I’m not sure how to turn them on since I have an XLT.
If somebody removed them, and you want to add fixed running boards, I would think the OEM running boards from an XLT max would work fine on the limited.
