Wile E Coyote
Our 07 Limited has a tough time keeping seat and mirror settings in memory. They work fine for a week or so, then next unlock the seat or mirrors move to waaay off positions. A reprogram works for a week or so, and then...
The pedals never seem to change, if it matters. This has been an issue since ownership (years now).
2nd more pressing issue is the oft-cited "jet on takeoff" sound from the engine cooling fan. (Locks up inappropriately, should be free-spinning at such times) It's intermittent but frequent enough to need attention. Spun by hand with engine off, fan turns easily when engine is cold and gets stiffer when engine is warm, as it should.
My question is; since the fan clutch has some degree of electrical control, where do I lay the blame? (fan clutch vs. ECM for example) No related codes noted on OBDII scanner.
