I need your help... So i just replaced my starter on my 99 expedition. The top bolt was a BEAR. So when took out the bottom mounting bolt it was a bit odd. It is threaded on both sides. So first i had to take the nut and wire off, I assume was the ground wire but not sure. Next I took out the rest of the both from the frame. The end of that bolt was stripped but i didn't think it was a big deal. Dumb i know. So I put everything back together but that bottom bolt was loose because it was stripped, I didn't give it another thought. I hooked the battery back up and wow it started. I tried to start it 30 mins later and it wouldn't start. I lightly tapped on starter and it started back up?? So do you think the bottom bolt being stripped and loose is somehow causing the problem is indeed that wire is the ground wire? Or is the remanufactured starter a lemon? I called Advanced and Oreilly and the both said it could be the lose/stripped bolt. I need to find a new bolt first. Ideas of what kind of bolt this is? I would appreciate your help. Thanks
