2012 Gator with the same 5.4 Triton
ran down a battery in accessory mode and needed a jump last night.
After it started, it would stay in 3500-4000rpm at highway speeds even with all the power draws off, so i thought OK, battery is kaput and it's trying&failing to rejuice it.. was going to walmart for tires anyhow, had em swap in a battery
NOW, rpms at speed are OK at ~1500... but MAJOR hesitation to start rolling, stalls out at long stoplights, idle surges around but surges low (200-400 ish), and when it stalls out it shows the "oil warning" icon and NO oil pressure (albeit if it's like the expy's, then that gauge is a fakeometer?)
First thought: walmart drained my oil by mistake
Popped hood, checked oil level, all OK.
Restarted, went home, stalled out once more and almost stalled a couple times again....
WTH????
WTH????
