Hey everyone,
1999 Expedition XLT 5.4 4WD
CEL came on tonight and upon checking it came up with P0171 and P0174 which are System Too Lean Bank 1 and System Too Lean Bank 2. I have done some looking around and have come up with several things that could be affecting this.
I am hoping that it is the PCV line because it seems to be an easy and cheapish fix. But like I said, there seems to be at least 4 different things that could be causing this, and I don't know another way to figure it out without replacing each and every part in hopes that it is the part that is causing the codes, and I can't do this.
I seen on another forum that if one code popped up, it could be the O2 sensor, but its unlikely for both to fail at the same time.
So anyways, I am looking for any advice on where to start, or someone who has had the same issues going on and can point me where to look.
Some recent issues that have started, that may or may not be related, but I feel I should disclose...
1. My blower does not seem to blow from the panel vents, its almost as if my heating system is stuck on defrost. When I turn the panel blower on, it blows out on top by the windshield. The vents for the feet work, and the rear works fine.
2. I have noticed that I am not getting as good of gas mileage as I recently did.
3. My gas gauge needle will jump around sometimes. Not from saying 1/4 tank to full tank, but like bobble up and down quickly.. This does not happen all the time, but it defiantly never used to happen!
Thanks for any help.
