gixer2000
Retrofit or Bust
Here's my project for the weekend. Lower steering shaft looks like it's going to be exciting... Living in the northeast is hard on components like this and I noticed a little stiffness in my steering wheel. I sprayed down the U joints and the stiffness disappeared so here's the replacement. I've seen fordtechmakulo video but it was on an f150 so I'm expecting something to be different. Anyone else done it that may have some tips?
The vacuum line is for the IWE solenoid. Includes the Check valve that I currently have an aftermarket from the Help section just to get by. I did have to hack up a couple of the lines to make the aftermarker check work so the lines need to go also. This will be smooth and easy so no questions on this
