Tire pressure
Grasshopper
Moore, OK
What are you guys running for air pressures?
Ford says to run the fronts at 26 and the rears at 32 IIRC.
G
Grasshopper
Moore, OK
Is that what your manual and/or door sticker says??? Mine says what I posted above.
slo-ryd
Ky
If they are factory size tires, the door sticker is the guide.
Mine is 30F/35R
G
Grasshopper
Moore, OK
Interesting Chuck. Different years of truck, I guess. Is yours a 4x4 like Buck Nasty's?
wickman
Maple Valley WA
Those morons at the NAPA tire center put friggin 90 psi in my tires. Every time I hit a bump I blew a valve stem. I was not a happy camper. I didn't figure I needed to check my tire pressure after having them mounted. After the second flat in less than 2 weeks, the tire guy in Whitehorse Yukon checks the rest and tells me that they are at 90 psi.
sharprd65
