Should be a little more than 40% by my calcs (7.5/13) in the event that helps.Holds so much your probably only getting yo change 30% ish when doing the drain pan and filter.
Valvoline Maxlife is SP compatible.correct, i was mixing up SP.... if you have 6R75, you have SP, and as far as i know there is no compatible replacement for SP
