TSB 23-2364 - 2023 Exp/Nav 3.5L EcoBoost - Reduced Engine Power On Start Up, Illuminated MIL And/Or Wrench Indicator With DTC P2101 In The PCM
HazBeen
Great Lakes
TECHNICAL SERVICE BULLETIN 23-2364
3.5L EcoBoost/3.5L PowerBoost - Reduced Engine Power On Start Up, Illuminated Malfunction Indicator Lamp (MIL) And/Or Powertrain Malfunction (Wrench) Indicator With DTC P2101 In The PCM - Built On Or After 01-Oct-2022
November 30, 2023​
Model:
Ford
2023 Expedition
Built on 01-Dec-2022 and through 30-Apr-2023
2022 F-150Engine: 3.5L EcoBoost, vehicles built on or after 01-Oct-2022
2023 F-150Engine: 3.5L EcoBoost, vehicles built on or after 01-Oct-2022
Engine: 3.5L PowerBoost, vehicles built on or after 01-Oct-2022
Lincoln
2023 Navigator
Issue: Some 2022-2023 F-150 vehicles equipped with a 3.5L EcoBoost engine built on or after 01-Oct-2022, 2023 F-150 vehicles equipped with a 3.5L PowerBoost engine on or after 01-Oct-2022, and 2023 Expedition/Navigator vehicles built on 01-Dec-2022 and through 30-Apr-2023 may exhibit reduced engine power on startup and an illuminated MIL and/or powertrain malfunction (wrench) indicator with diagnostic trouble code (DTC) P2101 stored in the powertrain control module (PCM). This may be due to the software level of the PCM. To correct this condition, perform the Service Procedure below to reprogram the PCM to the latest software level via the Ford Diagnosis and Repair System (FDRS).
Action:
Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• One of the following vehicles:
- 2022-2023 F-150 built on or after 01-Oct-2022 equipped with a 3.5L EcoBoost engine
- 2023 F-150 built on or after 01-Oct-2022 equipped with a 3.5L PowerBoost engine
- 2023 Expedition/Navigator built on 01-Dec-2022 and through 30-Apr-2023
• DTC P2101 stored in the PCM
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Emissions Warranty/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/Emissions Warranty/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2022-2023 F-150 3.5L EcoBoost/PowerBoost, 2023 Expedition/Navigator: Reprogram The Appropriate Modules As Required By The Software Update And Service Procedure (Do Not Use With Any Other Labor Operations)
MT232364​
Actual Time​
Repair/Claim Coding
Causal Part:RECALEM
Condition Code:04
Service Procedure
1.
Reprogram the PCM using the latest software level of the FDRS diagnostic scan tool. Follow all on-screen instructions carefully to complete all coordinated module software updates.
NOTE: Advise the customer this vehicle is equipped with an adaptive transmission shift strategy which allows the vehicle's computer to learn the transmission's unique parameters and improve shift quality. When the adaptive strategy is reset, the computer will begin a relearning process. This relearning process may result in firmer than normal upshifts and downshifts for several days.
© 2023 Ford Motor Company
All rights reserved.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
  • TSB 23-2364 - 3.5L EcoBoost-3.5L PowerBoost - Reduced Engine Power On Start Up, Illuminated Ma...pdf
tifanydire
