Tuning software available from 5 star
I’ve often wondered if Ford uses different camshafts in the HO EcoBoost. This is what they did to the 6.2L V8, Super Duty trucks and Raptor units had different cams in the heads so the motors breathe differently. One was optimized for torque and longevity and another for peak power output and acceleration.
M
Mike Wolfe
Tonopah AZ
My company supplied parts to Ford
I am a retired fuel & emissions system engineer
I worked with several of the emission & powertrain engineers
The engineers I know at FORD tell me the engines are identical except for ECU programming in the Expedition & NAVI
The GT engine uses the same short block with different cams, turbo's & higher flow injectors. Also a much higher flow exhaust system & Air intake system
So I guess I am challenging your assessment
I know for sure these engines are capable of producing much more power with premium fuel & new software as I have done with my last 4 eco boost 3.5L engines :33:
Drove an 2011 F 150 over 100k miles with recalibration with absolutely no durability issues
Uturn
I understand. So here it is from the Navigator owners manual and I will agree that the GT40 probably has more cam, bigger turbos, and injectors.
Engine Specifications
Measurement Specification
Cubic inches 214
Firing order 1-4-2-5-3-6
Ignition system Coil on plug
Compression ratio 10.0:1
Spark plug gap 0.028 in (.7 mm) - 0.031 in (.8 mm)
Link; http://www.fordservicecontent.com/F...&div=l&vFilteringEnabled=False&userMarket=USA
From the Expeditions Owners manual.
Engine 3.5L EcoBoost
Cubic inches 214
Compression ratio 10.5:1
Link; http://www.fordservicecontent.com/F...&div=f&vFilteringEnabled=False&userMarket=USA
And from the GT40.
ENGINE SPECIFICATIONS
Specification Measurement
Cubic inches 214 in³ (3,506 cm³)
Spark plug 0.030 in (0.75 mm)
Compression ratio 9:1
Fuel quality Premium fuel only
Link;http://www.fordservicecontent.com/F...-Owners-Manual-version-1_om_EN-US_10_2016.pdf
