Currently my reverse lights are not working due to lack of power to wires. Had my local mechanic shop test the wires from tranny to the bulbs. When he applied power to the harness the lights came on. he then checked the wires going from tranny to the cab and found nothing broken or grounded just no power. He said it is probably under the dash.
I removed the lower panel and tried to find the light blue/pink wire for the reverse lights and discovered that there were multiple none of which showed up on the wiring diagram. Found one even connected to the 4x4 switch near to my radio.... i desperately need help with this cause the inspection is almost up....
