Hey guys, so just got done everything with leveling my truck and ran into an issue...
So you know here's what I put on:
New complete struts all around
New sway bar end link
New tie rod end
New upper control arm+ball joints
Had the small issued I had worked out and it was aligned last Friday think 5/6/16... Anyways I drove it for a few days now and when I got out to check everything today after work the New control arm/ball joint I got from NAPA on the passenger side has failed...
It failed in the sense that the rubber housing around the joint came up a bit and exposed the insides and that grey grease poured out everywhere on the suspension... The shops all day they give me free labor and alignment and napa says they'll replace it again but why does this happen? And is napa not selling a quality part? Or is this mainly because of the leveling kit? Or should I be buying a different arm/joint that's more "heavy duty"?
If anyone can chime in its greatly appreciated so I don't keep running into this problem over and over... Also the new arm and joint will be put on tomorrow and alignment in afternoon...
Thanks guys
Edit: Figured I'd attach some pics so you can see what I mean...
New tie rod end
Thanks guys
