whtbronco
BLUF: looking for a J2534 pass through adapter verified to work with the Gen 2 Expeditions for Forscan troubleshooting
Long version/story:
My wife called to say that Message Center showed Tire Pressure Monitor Fault on our 2004 EB. BTW, I think EB stands for too much crap. She was 400 miles from home and I did not send her with a scanner, oops. I figured it was likely just a TPMS sensor battery so I told her not to worry about it, she'd already checked all tire pressures. After refueling and thus restarting the fault did not return. When she got home I used my OBDII scanner and found the following DTC's.
DSM (Driver's Seat Module)
B2324 - Driver's mirror vertical position sensor circuit fault
B2320 - Driver's mirror horizontal position sensor circuit fault
B2316 - Passenger's mirror vertical position sensor circuit fault
B2312 - Passenger's mirror horizontal position sensor circuit fault
HEC (Hybrid Electronic Cluster)
U1262 - SCP data link fault
PCM (Powertrain Control Module)
B1600 - No PATS(Passive anti-theft system) ignition key transponder signal received
-Possible Reasons-
-Ignition key damaged
-PATS antenna/wiring damaged
-PCM (Powertrain Control Module) damaged
TPM (Tire Pressure Monitor)
U1041 Missing or incorrect vehicle speed signal
I cleared the DTC's and scanned it again. I repeated this process numerous times. Consistently getting the expected P1000(didn't finish test), occassionally getting B2320 and B2324 again. However, the scanner showed various systems with communication issues. Most common were EATC, 4x4, VMS and DSM, but they varied. So with that being all I could get from my scanner I grabbed the laptop with Forscan. I then learned Forscan couldn't see the modules on the MS bus unless I get a J2534 pass through adapter. I'm sure the problem on the MS bus will likely get worse so before that happens I need to get setup to identify and resolve it. I have looked all over and the only adapter that seems to consistently work on the early 200x Fords is the CarDAQ-Plus at $1780, ouch. Any suggestions on a more reasonably priced unit? Anyone have successful experience with the Mongoose-Plus that's only, cough, cough, $540?
Another day, ~100 miles and 3 drive cycles so I checked it again despite no noticable symptoms or CEL.
P1000 - OBD Systems Test Incomplete
VDM (Vehicle Dynamics Module)
C1991 - Module Calibration Fault
I then cleared the DTC's and hit refresh. I hit refresh multiple times and got different modules showing No Fault Code|! . So I decided to read the data stream for these modules and each of would randomnly change from the correct value to N/A. This was the case for everything I would prefer not to have, 4x4 CM, EATC, DCSM, DSM, VDM, VSM, TPM, PCSM. PCM, ABS and RCM all remained rock steady reporting the correct data stream info, but I believe these are on a different bus.
Only one recent vehicle change and that was to move my stereo amp wire from under the carpet against the driver seat to the center row. I simply moved it out to the wire path along the doors. Maybe I fubar'd something as it is a rather snug fit next to the driver seat.
Long version/story:
-Possible Reasons-
