Voltage check help please 2008
jman
frisco tx
Does anyone know or would someone be willing the check their voltage at the Throttle Control Motor wires with key in ON position? My TCM does not respond, Car will idle in limp mode with it unplugged, plug it back in and it stalls. Have tested continuity on every wire I can find to eliminate a bad or broken wire, have checked all wires to ground to see if there is a short. Scanner shows gas pedal is functioning, changed TPS, no change, and this is a new TCM. Codes all reference TCM. Found it strange that there is voltage on both wires to the TCM, which could be the issue, but I don't have a wiring diagram to verify grounding of TCM.
Any help is greatly appreciated before I spend a chunk of money replacing the PCM.
Deeser
Florida
Here are the pinpoint tests for the throttle position sensor
  • TP Diag.pdf
J
jman
frisco tx
Thank you for the testing info.
Current codes are 2101, 2104, 2110,2111,2135
I have had 0122& 0223 but voltage out of the pedal seemed to be withing range based on what I can find.
It has a new TPS and TCM, tried a new pedal but no change so I took it back.
The problem progressively got worse over about 100 miles, strongly believe PCM is the problem.
JamaicaJoe
Oviedo FL
Just for giggles, are there any leaks in the air plenum hose between the MAF sensor and the throttle body?
J
jman
frisco tx
I did do the starting fluid check around all joints and throttle body base, did not find a leak.
tifanydire
