ZombieSoldier
Well my buddy is gonna hook it up to his scanner today and let me know what it is. He's a tech at a stealership.
did you ever get that p0453 before you changed your fuel pump? Diagnostic Trouble Code (DTC) P0453 indicates that Self-Test has detected a fuel tank pressure sensor (FTP) circuit input above the maximum limit.
Possible causes:
- FTP open.
- FTP short to VREF or VPWR.
- VREF shorted to VPWR.
- SIG RTN open.
- Damaged FTP sensor.
- Damaged PCM.
The FTP is located on top of the fuel tank. To replace it, the the Ford Manual states as follows:
1. Remove the fuel tank.
CAUTION: The fuel tank pressure sensor must be disengaged from the fuel tank before it can be removed. Failure to do so can cause damage to the fuel tank pressure sensor or the fuel tank.
2. Remove the fuel tank pressure sensor.
- Disconnect the electrical connector.
- Press down and rotate the fuel tank pressure sensor counterclockwise and remove it from the fuel tank.
