Eric Mowrer
In my case it helps when I buy groceries. When I get home, if I open the back, usually something will fall out on the ground. But if I open the glass first, I can either retrieve some things or push them back so that when I open the back, they won't fall out.
One good brake check before you pull in the driveway will fix that!!
I use mine all the time. Unfortunately, this thing is so tall, it's pretty hard to reach anything unless it's pretty packed.
The Gen4 is definitely a higher opening than the Gen3. I'm 6-1 and I find myself leaning against the back to reach in the window and down. This of course gets your shirt dirty from the dust that accumulates on the back of the Exped.
