What should be spinning? Weird rubbing sound/feel
DetroitDarin
Low speed, especially while turning - odd deep rub sound/feel. It's almost as if it's binding a bit as if 4wd was engaged, OR I had worn-through a rotor (the rotors are fine). My welding guy thinks the 4wd isn't disengaging - suggested I get the truck off the ground and spin the wheels see what happens. I am sure the axle would spin - but as long as the front drive shaft isn't spinning everything should be okay, no?
D
DetroitDarin
found a possible solution - rear end fluid change + friction modifier. Gonna try it.
Mediamonkey11
Super Moderator
Super Moderator
Enumclaw, WA
Oh good!
See I'd have known that if ya had your year in your sig ;-)
I hope the fluid change helps though!
D
DetroitDarin
Do people put that specific of info in their sigs? Oh - there ya go. I see it in yours :) Welp, I wouldn't put 'No brown wire mod needed'....so...anywho. Thanks :)
Mediamonkey11
Super Moderator
Super Moderator
Enumclaw, WA
Just razzin' ya :)
I have had LSD rear ends do exactly what you're describing and a fluid change drastically improved their behavior.
PaulMedik
